Script
This activity runs a custom VB.NET or C# script.
Select the activity in the Designer Pane to configure the following property boxes.
Activity Name
Activity Description
Scripting Language
This property box lets you choose which programming language the script(s) will be compiled in when a Script or SDK Script activity is run.
To configure Scripting Language
- Add a Script activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
Scripting Language in the Properties Pane select VB.NET or C# for your programming language.
Note: Changing the scripting language will not delete any scripts. But, only scripts written in the selected language will be run.
Script
This
property box shows the organization of your script folders and the scripts configured by the Script activity. It also shows you the scripts' contents in a read-only format that you can copy and paste. You can open the Script Editor from this property box. To configure the Script property box
- Add the Script activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- In the Script property box, select a script in the Script folder tree, and click the script's read-only contents in the Properties Pane to open that script in the Script Editor. Alternatively, double-click the script in the folder tree.
Script's Default Entry
Advanced
Configure how to treat unhandled script exceptions.
- Server Default: Use the Workflow Server default setting set in the Scripting Options dialog box in the Workflow Administration Console.
- Errors: Workflow treats unhandled script exceptions as errors that terminate the workflow instance.
- Warnings: Workflow treats unhandled script exceptions as warnings. The workflow instance continues running.
- Check for retryable errors: Workflow can handle certain types of exceptions and will attempt to automatically retry the script instead of reporting a warning.
Note: Each workflow definition that has a script activity maintains two projects, one for VB and one for C#, that contain common code and a list of external reference assemblies that the activities can use. Each activity adds one or more code files to one of the scripting projects, and when the workflow definition is published, the two projects are compiled into separate assemblies.
Related Topics
