AI Token Usage Node
The AI Token Usage node, under Monitoring in the Workflow Administration Console, lets you view and analyze token usage for large language model (LLM) services used in Workflow.
This node contains two subnodes: Usage Details and Usage Statistics.
To open the Usage Details or Usage Statistics node
- In the Workflow Administration Console, expand the Monitoring node.
- Expand the AI Token Usage node.
- Select either Usage Details or Usage Statistics.
