Character Classes
The following regular expression characters find a match if any one of the characters included in the set matches the criteria you define.
Regular Expression Description
Matches to any character except \n.
Note: In the Find Activity Pane, this character refers to any character (including \n).
Note: To match a period character, you must precede the period with the escape character (\). It should look like: \.
[aeiou] Matches any single character included in the specified set of characters.
[^aeiou] Matches any single character not in the specified set of characters.
[0-9a-fA-F] Use of a hyphen ( – ) allows specification of contiguous character ranges. Match any single character that ranges from the left side of the hyphen to the right side.
\p{name} Matches any character in the named character class specified by {name}. Supported names are Unicode groups and block ranges. For example, Ll, Nd, Z, IsGreek, and IsBoxDrawing.
\P{name} Matches any character that is not included in groups and block ranges specified in {name}.
\w Matches any word character. Equivalent to the Unicode character categories [\p{Ll}\p{Lu}\p{Lt}\p{Lo}\p{Nd}\p{Pc}]. If ECMAScript-compliant behavior is specified with the ECMAScript option, \w is equivalent to [a-zA-Z_0-9].
\W Matches any nonword character. Equivalent to the Unicode categories [^\p{Ll}\p{Lu}\p{Lt}\p{Lo}\p{Nd}\p{Pc}]. If ECMAScript-compliant behavior is specified with the ECMAScript option, \W is equivalent to [^a-zA-Z_0-9].
\s Matches any white-space character. Equivalent to the Unicode character categories [\f\n\r\t\v\x85\p{Z}]. If ECMAScript-compliant behavior is specified with the ECMAScript option, \s is equivalent to [ \f\n\r\t\v].
\S Matches any non-white-space character. Equivalent to the Unicode character categories [^\f\n\r\t\v\x85\p{Z}]. If ECMAScript-compliant behavior is specified with the ECMAScript option, \S is equivalent to [^ \f\n\r\t\v].
\d Matches any decimal digit. Equivalent to \p{Nd} for Unicode and [0-9] for non-Unicode, ECMAScript behavior.
\D Matches any nondigit. Equivalent to \P{Nd} for Unicode and [^0-9] for non-Unicode, ECMAScript behavior.
(expr) Match group. Captures the information that matches the expression in parentheses to be stored as a token value, etc.
(?:expr) Non-capturing group. Groups the contained expressions together, but does not restrict the information to be captured to only that group.
(?=expr) Captures information that is followed by the expression.
