Opening a Saved Workflow Definition
Saved workflow and business process definitions are opened in the same way.
To open a saved workflow or business process definition
- Select
File > Open in the main menu. Alternatively, use the keyboard shortcut CTRL+O. - Browse to and
select a Workflow Designer file (.wfx). - Click Open.
