Searching
You can search for a specific workflow or business process instance using the Search Pane. Results will be displayed in the Search Results Pane.
To perform a new search
- Open the Search Pane by clicking View in the main menu and selecting Search.
- Select one or more search types you want to perform.
- Once all desired search types have been configured, click Search. Search results appear in the Search Results Pane.
Note: Ampersand (&) and percent sign (%) symbols function as wild cards.
To open a saved search
- Click the
Common Searches button to open the Common Searches Pane. - Under My Searches, click the name of a saved search to perform the saved search.
Tip: You can modify a saved search and save your changes.
to open the
