Workflow Statistics Report
You can create workflow statistics reports that show a variety of information about running, completed, and terminated workflows. The results of these reports are displayed in a workflow statistics report results tab.
To configure a workflow statistics report
  1. Select Workflow from the main menu.
  2. Click Create Workflow Statistics Report.
  3. In the Create New Report dialog box, configure the search types to return the desired workflow statistics. When you select a search type, the dialog box will expand so that you can enter additional information.
    • Latest Version: Return only the latest version of each workflow in the search results.
    • Status: Return active, completed, and/or terminated workflows only.
    • Workflow Name: Only return workflows with a specific name. Type in a workflow name, or select one from the drop-down menu.
    • Start Time: Return workflows that started in a specified timeframe. Use the drop-down menu to choose from a variety of timeframe options.
    • Time of Last Action: Return workflows that were active in a specified timeframe. Use the drop-down menu to choose from a variety of timeframe options.
  1. Click OK.
  2. Your results will appear in a workflow statistics report results tab.
