Error Code Range 9400-9499
Need more help?
If an error code on this page doesn’t link to a resolution or isn’t clear, please scroll to the bottom of the page, click "No" under Was this page helpful?, and let us know which error code you need more information about in the following feedback page.
Your feedback helps us improve the documentation for you and for all Laserfiche customers.
Error Code Error Description
9400 All dynamic field definition queries must have the query text defined.
9401 The dynamic field query is not correctly formed.
9402 The default dynamic field query may not have a query condition or require a value.
9403 This function is only available for full-text search within a document.
9404 A bind variable type cannot be resolved.
9405 Invalid search collation rule.
9406 Search collation rule is supported with Oracle 10g or higher.
9407 The briefcase is encrypted. A password is required to import it.
9408 The full text search statement is empty.
9409 Fail to initialize the external table.
9410 Invalid LFQL collation rule.
9411 LFQL collation rule is supported with Oracle 10g or higher.
9412 A cryptographic function either failed or was not available.
9413 The DBMS of this repository does not support the use of the LIMIT and the OFFSET keywords.
9414 Unknown LFLIST table.
9415 LFLIST table
9416 Signature not found.
9417 Unable to register an external table that contains an invalid column type.
9418 Certificate not found.
9419 Invalid certificate thumbprint.
9420 The Laserfiche query you have entered is too complex to process. Please rewrite the query.
9421 Invalid search catalog status.
9422 The SQL column type is not supported in LFQL.
9423 The specified security classification level was not found.
9424 Cannot file an entry with a higher security classification level in a folder of a lower classification level.
9425 The specified discussion alert template was not found.
9426 The specified comment template was not found.
9427 The specified discussion was not found.
9428 The specified topic was not found.
9429 The specified comment was not found.
9430 The specified discussion watch was not found.
9431 The specified topic watch was not found.
9432 The signature could not be deleted because there are countersignatures that depend on it.
9433 Unknown XML property encountered.
9434 An error was encountered in the XML signature library.
9435 An invalid certificate was specified.
9436 An invalid signing key was specified.
9437 ORDER BY items must appear in the select list if SELECT DISTINCT is specified.
9438 The specified certificate could not be trusted.
9439 The text, ntext, and image data types cannot be sorted.
9440 The ASN1 encoder encountered an error.
9441 The ASN1 decoder encountered an error.
9442 Failed to issue a timestamp request to the TSA.
9443 Received an invalid response from the TSA.
9444 The timestamp request was rejected by the TSA.
9445 Search plan not found.
9446 Search plan build failed
9447 Search plan build failed
9448 The SQL data type of a column is not supported by the ODBC driver. Please check the event viewer on the Laserfiche Server machine for more information.
9449 The SQL data type of a column in the external table is not supported.
9450 Only full-text searches can be used with the WITHIN operator.
9451 The search catalog could not be created or it failed to start.
9452 The repository has been successfully attached but the search index catalog needs to be upgraded. Please run the Full-Text Search Catalog Upgrade Wizard to update it. Until a catalog is attached or created, you will not be able to run full text searches on the repository or index your documents. You may attach the associated catalog or create a new one through the Index node in the Laserfiche Administration Console. If you create a new catalog, you will need to reindex your repository.
9453 An audited event cannot be completed while the auditor is locked down.
9454 The connection string is incompatible with the DBMS type of the repository.
9455 Failed to set up the dynamic fields due to a type conflict. The type of the field and the type of the SQL column must be compatible.
9456 Failed to set up the dynamic fields as specified.
9457 Unknown Laserfiche external table column name.
9458 Failed to connect to the LFS helper process.
9459 LFS helper process returns invalid result.
9460 The LFS helper executable file is not found.
9461 Failed to start the LFS helper process.
9462 The access control list (ACL) could not be modified because the size would exceed the 64 KB limit.
9463 Failed to create a record series with an empty series code. The repository option "Require unique series code" is set to true.
9464 This catalog is from an earlier version of Laserfiche.
9465 The time-stamp request could not be processed.
9466 The time-stamp authority is disabled.
9467 The time-stamping library could not be loaded.
9468 The time-stamp authority profile was not found.
9469 Error removing the time-stamp authority profile.
9470 Error storing the time-stamp authority profile.
9471 Error reading the time-stamp authority profiles from the registry.
9472 The search engine encountered an error when parsing the full text search query.
9473 The digital time-stamp cannot guarantee that this data existed prior to the specified cutoff time.
9474 The time-stamp has an invalid signature.
9475 Error reading search catalog name or UUID.
9476 Error reading search engine's URL.
9477 Error reading search engine's port.
9478 Error reading search catalog's path.
9479 Error connecting to the search engine. Either the search engine is offline or the search engine connection settings are misconfigured. Please contact your Laserfiche administrator.
9480 The review setting for vital records was not found.
9481 The review interval unit was not found.
9482 Invalid review interval. The interval length must be greater than 0 and the interval unit must be defined.
9483 The review interval unit is missing.
9484 Vital records can only be reviewd by a calendar cycle or by a time interval.
9485 Invalid stop word found in the stop word list.
9486 Failed to attach a search catalog.
9487 Counter-signing is only allowed for signatures on the same document.
9488 The latest version of a version-controlled document cannot be deleted.
9489 Failed to create a search catalog. A duplicate search catalog was found for the search engine.
9490 The search catalog failed to start. One or more required index files are missing.
9491 The search catalog is in read-only mode. Full-text search is available, but indexing and stop word updating are disabled.
9492 The search catalog failed to start. The search catalog failed to log in to the repository due to an invalid username or password.
9493 The search catalog failed to start. The catalog settings are mis-configured.
9494 Failed to attach a search catalog. CatalogConfig.xml is missing.
9495 Failed to attach a search catalog. CatalogConfig.xml is invalid.
9496 This field definition cannot be changed because one or more entries exist with values in the version history.
9497 A duplicated catalog is found in the search engine.
9498 Failed to find the full-text search session. The connection to the search engine might have been reset.
9499 Failed to cutoff the record or the record folder. One or more required records are checked out.
