Customizing Public Portal
Public Portal can be customized to meet your organization's needs. For example, you can add custom links to your Welcome page, modify search options, and change the site's colors and logos.
To customize Public Portal, you can use the Public Portal Designer. User accounts with the Public Portal Administrator right can access the Designer from the app picker when signed in to Laserfiche Cloud.
To view the newly customized pubic portal, click the username at the top right, then click View Public Portal.
Configuration Options
The following sections of the Public Portal Designer let you customize various aspects of Public Portal
