Assign Field Values
This activity assigns and reassigns a template and field values in a Laserfiche entry. A field value is a piece of information in a field about a document or folder. This could be, for example, an author’s name, an invoice number, or an address. A template is a collection of fields. Only one template may be applied to a document or folder at a time. Learn about the tokens this activity produces.
To set up this activity:
- In the Template property box, select a template.
- Keep the current template: Keeps the template currently assigned to the Laserfiche entry.
- Unassign the current template: Removes the template from the Laserfiche entry.
- Assign the following template: Assigns a new template to the Laserfiche entry. Click the Token button (right arrow)
to add a token. - When you unassign or assign a template, select Remove fields from unassigned templates to remove all fields associated with the entry's starting template. Clear the checkbox so that the template's fields remain associated with the entry even though the template is removed.
- In the Field Values property box, click Choose fields... to add fields.
- Select the fields from the list you want to assign values to. If a template is assigned in the Template property box, only the fields in that property box are available.
- Click OK.
- Configure the field in the property box.
- In the Assign Field Values To property box, select the Laserfiche entry you want to assign field values to. Learn more about selecting an entry
Tokens for Assign Field Values Activity
| Name | Description | Sample Syntax |
| Template_Id | The ID number of the template assigned to the entry. Note that this token's value will be "-1" if no template is assigned to the document. | %(AssignFieldValues_Template_Id) |
| Template Name | The name of the template assigned to the entry. | %(AssignFieldValues_Template Name) |
| Template_Name | The name of the template assigned to the entry. (Legacy format) | %(AssignFieldValues_Template_Name) |
| Parent | If an entry and the folder it is in (its parent folder) have the same field, this token represents the field value of the parent folder’s field. The token %(Parent:Fieldname) represents the value of a different parent field. These tokens can only be used with fields. | %(Parent) |
The "AssignFieldValues" portion of the syntax changes to match the activity's name.
