Assign Token Values
Assign Token Values activity
This activity creates new tokens and update the values of existing tokens.
Example: For an upcoming meeting, you want to know how many people added their signature to a multi-value Approver field on the agenda. You use the Assign Token Values activity to create a custom token, Signature Count, with a value of zero. You then add a For Each Value activity that goes over each signature in the Approver field. Inside the For Each Value activity, you place a Token Calculator activity configured to add 1 to the Signature Count token for each value found in the Approver field. Also inside the For Each Value activity is an Assign Token Values activity that updates the Signature Count token with the value of the Token Calculator token. The resulting Signature Count token tells you how many people signed the agenda.
To create a new token:
  3. In the Tokens property box, click Create....
  4. Next to Token name, type a unique name for the token.
  5. Optional: Select Allow token to have multiple values to make the token a multi-value token.
  6. Under Value, type a token value. Click the Token button (right arrow) Right arrow to add a token.
  7. Expand the Token Tags section and select the categories relevant to your new token. Learn more about token tags
  8. Click OK.
To update an existing token:
  3. In the Tokens property box, click Modify....
  4. Next to Activity, select from where you want to get the token.
  5. Next to Token, select the existing token.
  6. Under New value, type a new value for the token. Click the Token button (right arrow) Right arrow to add a token.
  7. Click OK.
To modify a token after creating or modifying it, click the Edit button Edit button. To delete a created or modified token, click the Delete button Delete button.
