Change Starting Entry
Change Starting Entry activity
This activity changes the starting entry to a specified entry or updates the Entry Name and Entry Path tokens to reflect the entry’s current name and path. Learn about tokens this activity produces
Note: All the activities listed below the Change Starting Entry activity in the Designer pane act on the entry specified in this activity by default.
To set up this activity:
  3. In the Entries property box, select the Other Entry radio button, then the Edit button Edit button, and choose the entries you want this activity to operate on.
    Note: Select Refresh the starting entry's tokens to use the same starting entry but with new tokens.
Tokens for Change Starting Entry Activity
Tokens
PreviousEntry_Name The name of the previous starting entry. %(ChangeStartingEntry_PreviousEntry_Name)
PreviousEntry_Id The Laserfiche ID number of the previous starting entry. %(ChangeStartingEntry_PreviousEntry_Id)
PreviousEntry_Path The folder path of the previous starting entry. %(ChangeStartingEntry_PreviousEntry_Path)
PreviousEntry_FullPath The folder path of the previous starting entry, including the entry's name in the path. %(ChangeStartingEntry_PreviousEntry_FullPath)
PreviousEntry_Repository The repository the previous starting entry was in. %(ChangeStartingEntry_PreviousEntry_Repository)
OutputEntry_Name The name of the starting entry specified in this activity. %(ChangeStartingEntry_OutputEntry_Name)
OutputEntry_Id The Laserfiche ID number of the starting entry specified in this activity. %(ChangeStartingEntry_OutputEntry_Id)
OutputEntry_Path The folder path of the starting entry specified in this activity. %(ChangeStartingEntry_OutputEntry_Path)
OutputEntry_FullPath The folder path of the starting entry specified in this activity, including the entry's name in the path. %(ChangeStartingEntry_OutputEntry_FullPath)
OutputEntry_Repository The repository that contains the starting entry specified in this activity. %(ChangeStartingEntry_OutputEntry_Repository)
EntryWasFound Whether the new starting entry selected in this activity was successfully found in the Laserfiche repository. This token can have one of two values: True or False. %(ChangeStartingEntry_EntryWasFound)
The "ChangeStartingEntry" portion of the syntax changes to match the activity's name.
Note: All non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity "'Refresh' Tokens", the syntax for the PreviousEntry_Id token will be "%(RefreshTokens_PreviousEntry_Id)".
