Delay
This activity delays part or all of a workflow from running. If the activity is contained in the branch of another activity, only the branch is delayed.
To set up this activity:
In the Delay Duration property box, specify the delay period.
- Select Delay for to delay part or all of a workflow for the specified length of time.
- With the Exclude weekends and holidays option, you can exclude weekends and holidays from the specified length of time. The excluded weekends and holidays are based on those set up in your work schedule profile.
- With the Test Duration Date option, you can test how long the activity delays based on a provided value. When you select this option, a dialog appears, in which you can type a start date and (if you have tokens in the Delay for section) sample values. When you click OK, the resulting delay is returned.
- Select Delay until to delay based on a specific date and time.
