Delete Entry
This activity deletes an entry in your Laserfiche repository. An entry can be a document or folder.
To set up this activity:
- In the Connection Profile property box, select the repository you want the activity to use.
- In the Options property box, select additional deleting options.
- Purge entry after deleting: Permanently deletes the entry from the Laserfiche repository, purging the entry from the Laserfiche recycle bin after the entry has been deleted. Note that purging an entry is irreversible.
- Only delete empty folders: Only deletes folders that contain zero entries.
- In the Entry to Delete property box, select the entry you want to delete. Learn more about selecting an entry
