Move Entry
Move Entry activity
This activity moves, copies, or creates a shortcut to an entry. Learn about tokens this activity produces.
To set up this activity:
  3. In the Action property box, select the type of action on the entry.
    • Move: Relocates the entry to the destination specified.
    • Copy: Duplicates the entry.
    • Create Shortcut: Places a shortcut to the entry in the destination specified.
  4. In the Destination property box, type the path to an entry or, using the Browse button (ellipsis) Browse button, browse to the entry. Click the Token button (right arrow) Right arrow to add a token.
    Note: You can only type a destination in the current Laserfiche repository.
  5. Select an action if the path does not exist.
    • Create it: Creates a new folder path.
    • Create it and report a warning: Creates a new folder path and displays a warning in the search results and the instance report.
    • Terminate the workflow: Ends the workflow and displays an error in the search results and the instance report.
  6. In the Entry to Move property box, select the entry you want to move. Learn more about selecting an entry
Tokens for Move Entry Activity
Tokens
OutputEntry_Name The name of the moved entry. %(MoveEntry_OutputEntry_Name)
OutputEntry_Id The Laserfiche ID number of the moved entry. %(MoveEntry_OutputEntry_Id)
OutputEntry_Path The folder path of the moved entry. %(MoveEntry_OutputEntry_Path)
OutputEntry_FullPath The folder path of the moved entry, including the entry's name. %(MoveEntry_OutputEntry_FullPath)
OutputEntry_Repository The repository the moved entry is in. %(MoveEntry_OutputEntry_Repository)
ParentFolder_Name The name of the folder the entry was moved into. %(MoveEntry_ParentFolder_Name)
ParentFolder_Id The Laserfiche ID of the folder the entry was moved into. %(MoveEntry_ParentFolder_Id)
ParentFolder_Path The folder path of the folder the entry was moved into. %(MoveEntry_ParentFolder_Path)
ParentFolder_FullPath The folder path of the folder the entry was moved into, including the folder's name. %(MoveEntry_ParentFolder_FullPath)
ParentFolder_Repository The repository that contains the folder the entry was moved into. %(MoveEntry_ParentFolder_Repository)
Created Parent Folder Whether the Move Entry activity created the folder the entry was moved into. This token can have one of two possible values: True or False. %(MoveEntry_Created Parent Folder)
The "MoveEntry" portion of the syntax changes to match the activity's name.
Note: All non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity "Transfer to ~Sales_Top~", the syntax for the OutputEntry_Id token will be "%(TransfertoSales_Top_OutputEntry_Id)".
