Rename Entry
Rename Entry activity
This activity renames a Laserfiche entry. Learn about tokens this activity produces.
To set up the activity:
  3. In the Connection Profile property box, select the repository you want the activity to use.
  4. In the New Entry Name property box, type the entry's new name. Click the Token button (right arrow) Right arrow to add a token.
  5. In the Entry to Rename property box, select the entry you want this activity to rename. Learn more about selecting an entry
Tokens for Rename Entry Activity
Tokens
OutputEntry_Name The new name of the renamed entry. %(RenameEntry_OutputEntry_Name)
OutputEntry_Id The Laserfiche ID number of the renamed entry. %(RenameEntry_OutputEntry_Id)
OutputEntry_Path The folder path of the renamed entry. %(RenameEntry_OutputEntry_Path)
OutputEntry_FullPath The folder path of the renamed entry, including the entry's new name. %(RenameEntry_OutputEntry_FullPath)
OutputEntry_Repository The repository the renamed entry is in. %(RenameEntry_OutputEntry_Repository)
The "RenameEntry" portion of the syntax changes to match the activity's name.
Note: All non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity "Standardize/Names", the syntax for the OutputEntry_Id token will be "%(StandardizeNames_OutputEntry_Id)".
