Set Entry Owner
Set Entry Owner activity
This activity makes a user an entry's owner or removes an owner from an entry. A user who owns an entry automatically has the security permissions to manage the entry, even if the user does not otherwise have the relevant rights or privileges. Learn about tokens this activity produces.
Example: The supervisor at a company is the current entry owner for a document that contains the newest purchase order. The supervisor wants to transfer the operations of the document to one of the supervisor's employees. To transfer ownership, the supervisor can email the entry to the employee using an Email activity, and then, using the Set Entry Owner activity, change the entry owner to the employee.
To set up this activity:
  3. In the Owner property box, set or clear the entry owner associated with an entry.
    Note: You can only specify users, not groups, as entry owners with this activity.
    • Set entry owner to: Lets you select a user to associate with an entry.
      • The workflow initiator: Lets you set the user who satisfied the workflow's starting event or who was specified as the initiator.
      • The user from: Lets you select an entry to specify the user with whom a previous activity in your workflow interacts. You can select the entry using the Edit button Edit button.
        Note: Currently, you cannot use this option to select a user.
      • The user with account name: Lets you type the account name of the user or browse to the user with the ellipsis Browse button. Click the right arrow Token button to add a token.
    • Clear the entry owner: Lets you remove a user associated with an entry.
  4. In the Set Owner For property box, select the entry. Learn more about selecting an entry
Tokens for Set Entry Owner Activity
Tokens
New User Name The account name of the new entry owner. %(SetEntryOwner_New User Name)
Old User Name The account name of the entry's owner before this activity assigned a new owner. %(SetEntryOwner_Old User Name)
The "SetEntryOwner" portion of the syntax changes to match the activity's name.
Note: All non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity "Assign-to-@Initiator", the syntax for the New User Name token will be "%(AssigntoInitiator_New User Name)".
