Using the Token Dialog
The Token Dialog lets you view and modify tokens.
The Token Dialog
  1. Click the Token button (right arrow) Right arrow to add a token.
  2. Select Token Dialog... from the drop-down menu.
  3. Token Dialog option
  4. In the dialog box, expand the drop-downs to select a token. Use the search box to search for a token.
  5. In the text box at the top, select the token to configure it in the Token Editor. You can click Show tokens as plain text to edit tokens as text.
  6. Click OK.
