Field Lookup (Real-Time Lookup)
Lookup processes retrieve information from a third-party database and store them with the document processed in Quick Fields. As a real-time process, Field Lookup can be used in various stages of processing, including to update information during Revision. Field Lookup matches one or more values extracted from a document with a column or columns in a third-party database. When a match is found, any value from the corresponding row in the database can be used to identify a page, populate a field, determine the document name, or determine where the document will be stored. The lookup will pull data from the first row whose columns match the specified inputs. The lookup can begin when a field is updated, when a specified key is pressed, or when the document is processed.
Note: Field Lookup works similarly to the Lookup process available in processing, but can run during Revision and does not have access to additional tokens generated by other processes.
Example: A school district is scanning student records. Each student record has the student's ID in the top right corner. The school district has an external database containing each student's name, ID, social security number, and phone number. Quick Fields uses a Zone OCR process to OCR the student's ID in the top right corner of each scanned record and saves it as a token. That token is then compared to the external database. When the student ID that was extracted from the Zone OCR process matches an ID in the database, the other values in the row for that student (name, social security number, and phone number) are returned and used to populate the Name, Social Security Number, and Phone Number fields that are assigned to each student record scanned.
To configure a Field Lookup
  1. Select the name of the document class.
  2. At the bottom of the Tasks Pane, select Configure fields. You can also right-click the document class and select Configure fields from the context menu.
  3. In the Real-Time Processes tab of the Configure Fields for Document Class dialog box, select Add Process and Field Lookup.Configure Fields dialog box
  4. In the Summary step, you can specify a name and description for this Field Lookup process to help you or others remember its purpose at a glance.Configure Fields dialog box Summary tab
  5. In the Source step, specify the database to retrieve information from. You have three choices for the Configure Source Wizard: Windows ODBC, Advanced, and Expert.Configure Fields dialog box Source tab
  6. Once you have configured the database connection, in the Input step, you can specify data to look up in the database.Configure Fields dialog box Input tab
  7. Under Configure your query by, select if you want to configure it by selecting a table and columns or by writing your own custom query. Configure Fields dialog box Input tab
  8. If you selected to configure your query by selecting a table and columns, select the table from the Table list and click Add to choose the data to use in the lookup.Configure Fields dialog box Input tab
  9. In the Add Input dialog box, select a column from the database and the token from Quick Fields whose value you want to match and click OK
  10. Click Add again to configure an additional item to use in the lookup. Using more than one item will look up all the specified values. This is useful when more than one item in the database may meet some of the specified criteria. You can continue adding queries until they will identify unique columns.
  11. To modify an input, select it and click Edit. Make your changes and click OK.
  12. To remove an input, select it and click Remove.
  13. If you chose to configure your query by writing your own custom query in step 7, click inside the Query box to create a custom SQL query.
    Tip: When writing your own query, the token format to use is %(Column.ColumnName) where Column is always the same and ColumnName is what your query specifies. For example, select X as Y from Z would produce a column named Y, so the token would be %(Column.Y).
    Optional: You can click Test at the bottom of the Input step in the Configure Fields for Document Class dialog box to see how many results were returned or if there were any errors. If you are writing your own query, clicking Edit enables you to edit that query.
  14. In the Results step, configure which fields will be updated with what information when the Field Lookup process is run. Custom Fields dialog box Results tab
  15. To configure a field, click Add. The Configure Result Action dialog box will open. Select one of the fields associated with your document class and specify a value that will populate the field when the Field Lookup process is run. Column tokens represent information from the database you configured in earlier steps.
  16. To edit a result action, select it and click Edit. Make your changes and click OK.
  17. To remove a result action, select it and click Remove.
  18. In the Trigger step, you can configure when the process will run. You can select one or multiple options.Configure Fields dialog box Trigger tab
  19. Example: Angelica sets a Field Lookup to trigger when a field changes and when the document is processed. When a document is processed, information from the document will trigger the lookup that populates the fields from information from the database. During Revision, when reviewing the scanned documents and their metadata, she can change the field that is set to trigger the lookup and the data will be updated again.
    The choices for when to update a process are:
    • When a field changes: Select a field or fields.
    • When a key is pressed: Select the input box and press the desired keyboard shortcut to trigger the lookup.
    • When the document is processed: The lookup will run when the document is processed.
    Note: If you are using more than one input value, it is better to run the lookup after processing, when all the values have been generated.
  20. In the Options stage, you can select additional options for the Field Lookup.
    Configure Fields dialog box Options tab
The options are:
  • Perform field verification: Fields will be marked as unverified if the lookup returns no data.
  • Show field icons: The template will display "input" and "output" icons next to the appropriate fields.
  • Clear fields when no data is retrieved: If the database contains no data, the field will be cleared.
  • Log field changes: Changes will be logged to the output pane.
