Revision
When you capture documents with Quick Fields, you have the opportunity to review and revise them before storing them in Laserfiche (unless the session is set to store the documents immediately). Once documents have been scanned, the documents will appear in the Revision Pane and the pages of the currently selected document will appear in the Thumbnails Pane. You can perform quality assurance on the documents before storing them in Laserfiche. You can view the documents and pages, apply processes or groups of processes, or modify them in other ways, such as splitting a document into multiple documents or editing the document metadata.
