Saving Email to Laserfiche from Microsoft Outlook
Note: The Laserfiche Office Integration can be used when your organization does not yet have Office 365. Otherwise, the newer Laserfiche Outlook Add-in is recommended.
Office Integration is a Laserfiche component that allows users to take advantage of Laserfiche features when working with Office files in their native Microsoft Office applications. Office Integration allows you to save Office files directly to your repository from the Office ribbon or toolbar.
In addition to its integrations with Microsoft Word, Excel, and PowerPoint, Office Integration offers special features for importing emails from Microsoft Outlook to Laserfiche. You can save emails and attachments to Laserfiche manually, perform an import to a default folder with a single click, automatically extract information about your emails from their headers and save them to the new document's fields, and specify how to handle attachments.
Note: In addition to saving directly from within an Office application, you can also import Microsoft Office documents as you would any other file type. See Importing Files from Your Computer for more information.
Installing the Office Integration
If you have never used Office Integration on your workstation before, you will need to do so before you can save documents to Laserfiche from Office. This can be done by opening any Microsoft Office document in your repository. You will automatically be prompted to download and install Office Integration.This will save a file to your computer, which you can run to install Office Integration. Once you have installed Office Integration, you may be prompted to close any Microsoft Office applications you have open, and/or to restart your computer. If you are not prompted to do so, you will need to close and re-open your Office applications after installing.
Note: Sending Microsoft Outlook email messages to Laserfiche uses different options than sending other types of Office documents. See Saving to Laserfiche from Microsoft Office. However, the same Office Integration installation is used for both, so you do not need to reinstall Office Integration before using it with other Office applications.
Once you have installed Office Integration, you will see the Laserfiche ribbon or toolbar in your Microsoft Office applications. You can access the features of Office Integration from this ribbon or toolbar, including the Save to Laserfiche feature.
While saving an Office document to Laserfiche, you can configure metadata about that document to categorize it or make it easier to search for in the future. See Metadata for more information.
Configuring Outlook Import Options
You can configure default settings that will be used when importing emails from Microsoft Outlook. These will be used for all imports to a default folder (see Automatically Importing Selected Emails to a Default Folder), and will also be the default values when manually storing email in Laserfiche, although in that case you will have a chance to edit the properties before storing the emails (see Importing Emails to Laserfiche).
You can configure a default location for the imported emails, as well as template and field information and settings for attachment handling. The name, location, and field information can also draw from properties of the email itself. For instance, you can store the time the email was received in a field value, or you could dynamically store the emails in a folder named after the email's sender.
  1. If you are not already in the repository administration section of Laserfiche, open the app picker in the upper left corner and select Repository Administration.
  2. On the left, select Integrations and then Outlook Import.
  3. In the Default behavior option, determine how attachments will be handled. You can leave them in the email, remove them and file them as a separate document, or store them both within the original email and as a separate document.
  4. If you have chosen to store attachments separately, select Apply email fields to attachments to give the attachments the same template and fields as the parent email.
  5. In the Field associations option, select a template that will be applied to imported emails by default. The Email template has already been added and configured for you, but you can select another template, or modify which properties are stored in which fields.
  6. In the Default email import folder option, specify the repository location where emails will be stored by default. A path has been configured for you, but you can modify this path to store emails elsewhere. You can use the token dropdown to dynamically file emails. (For instance, in the pre-configured path, the sender name token is used to automatically store emails in a folder corresponding to their sender.)
  7. If you would like to return to the default options, click the Clear button under Reset.
  8. When you are finished configuring import options, click the Save button at the bottom of the screen.
Automatic email import will send your emails to the default folder specified in Repository Administration, using the document name and template and field settings configured there. Because these settings determine how the emails will be imported, you can import them with a single click. If you want to configure each email separately, see Importing Emails to Laserfiche, below.
Saving Emails to a Default Folder
Learn how to save emails from Outlook directly into the repository with minimal effort. Default folder configuration ensures emails are consistently filed and organized, with support for automated folder paths.
  1. In Microsoft Outlook, open the Laserfiche ribbon or toolbar. (You do not need to be logged in to Laserfiche in your browser.)
  2. Select one or more emails to import.
  3. Click Save to Default Folder.
When manually importing email, you can configure the properties for each new document separately. By default, the settings you configured for Outlook Import options will be used, but you can check each one and make changes before you store the email. If you want to use the default options for all emails in the batch, you can do so more quickly by saving to a default folder; see Automatically Importing Selected Emails to a Default Folder, above.
  3. Click Save to Laserfiche.
  4. If you have not yet worked with an Office document using Office Integration, you will be prompted to provide your Laserfiche URL. Type or paste the URL of your repository in the box, and click OK.
  5. You will be prompted to log in. Provide your user name and password, and click OK.
  6. In the General tab, you can specify a new name for the document, type a name in the Document Name option. (By default, the email subject will be used.)
  7. Navigate to the folder in the repository where you want to save the emails.
  8. In the Fields tab, you can modify the template and field information for your new document. See Fields for more information.
  9. If the email has attachments, the Attachments tab will be displayed. Configure the following:
    • To leave an attachment in the message, select Leave in Message. To import it as a separate document, select Separate Document.
    • If you have chosen to import the attachment as a separate document, select Apply settings to attachments that are stored as separate documents if you want to use the same metadata settings for your attachments as you do for the message.
    • If you have chosen to import the attachment as a separate document, select Message should be linked to attachments to connect the email and its attachment with a document relationship in Laserfiche. Select the relationship you want to use.
  10. In the Tags tab, you can add tags to the document. See Tags for more information.
  11. Optional: If you are importing multiple emails at once, you can select Apply these properties to all entries imported in this batch. This allows you to import multiple emails without having to configure each one individually.
  12. Click OK to save your emails to Laserfiche.
Importing Attachments to Laserfiche
  2. Select one or more emails with attachments that you want to import.
  3. Click Save Attachments to Laserfiche.
  4. You will be provided with a list of all the attachments in the selected email or emails. Deselect any attachments you do not want to import and click OK.
  5. If you have not yet worked with an Office document using Office Integration, you will be prompted to provide your Laserfiche URL. Type or paste the URL of your repository in the box, and click OK.
  6. You will be prompted to log in. Provide your user name and password, and click OK.
  7. In the General tab, you can specify a new name for the document, type a name in the Document Name option. (By default, the attachment's file name will be used.)
  8. Navigate to the folder in the repository where you want to save the emails.
  9. In the Fields tab, you can modify the template and field information for your new document. See Fields for more information.
  12. Click OK to save your attachments to Laserfiche.
