The Laserfiche Office Integration
Through the Laserfiche Office Integration components you can work with Microsoft 365 applications like Word, Excel, PowerPoint, and Outlook.
Working with Microsoft Office Documents
When working in Word, Excel, or PowerPoint documents, and depending on which Laserfiche client you use, you may need one or more of the following components:
  • Add-in: Saves Office documents directly to the repository if not working with a checked out document.
  • Tray app: Manages documents that you check out from the Laserfiche Repository Web Client.
  • Plug-in: Works with Office documents from the Laserfiche Repository Desktop Client.
Working with Microsoft Outlook
When working in Outlook, classic Outlook, or Outlook for the web, and depending on the type of email server, saving emails directly to Laserfiche will require one or more of the following components:
  • Outlook add-in: Works with new Outlook, classic Outlook, and Outlook for the web when using Microsoft Exchange Online.
  • Outlook plug-in: Works with the repository's Outlook import options when using a self-hosted Microsoft Exchange server.
Components at a glance
Laserfiche Office Integrations at a glance
Component What it does
Laserfiche Office Integration add-in Saves new Word, Excel, and PowerPoint files to the specified repository for the first time from desktop Office applications.
Laserfiche Office Integration tray app Lists and checks in Word, Excel, and PowerPoint documents that you checked out from the Laserfiche Repository Web Client.
Laserfiche Office Integration plug-in Provides certain Laserfiche features when working with Microsoft Word documents, Excel spreadsheets, PowerPoint presentations, and Outlook messages in their native Microsoft Office applications.
Laserfiche for Outlook add-in Saves emails and attachments, attaches repository documents to emails, and saves emails when you send them.
Legacy Integrations
Laserfiche for Outlook plug-in Saves emails and attachments using the repository's Outlook import options.
Which components do I need?
If you use the Laserfiche Repository Web Client, install or enable these:
  • Office add-in, install from the Office ribbon, click "Add-ins". An administrator must first deploy it for your organization. It may be automatically installed for you.
  • tray app, download the installer from the Laserfiche 12 installer.
  • Outlook add-in, install from the Outlook or Outlook for web ribbon, click "Add-ins". An administrator must first deploy it for your organization. It may be automatically installed for you.
  • Together, they let you save new documents and emails to the repository and to keep working with checked-out documents.
If you use the Laserfiche Repository Desktop Client, install this:
  • Office plug-in. This component is unchanged. The Laserfiche Repository Desktop Client does not use the tray app.
See Also:
