Destination Repository
This property box determines which repository entries are copied into with the Replicate Entries activity.
To configure Destination Repository
- Add the Replicate Entries activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
Destination Repository in the Properties Pane, use the drop-down menu to select which repository you want the entries to be copied into. - Optional: If the desired repository is not listed in the drop-down menu, select Manage Connections to add a connection profile for this activity to use.
