Filter Signatures
This property box determines which digital signatures will be retrieved with the Get Document Signatures activity.
Note: Digital signatures have reached end of life and creating new digital signatures is no longer supported. Existing digital signatures can still be viewed, validated, and deleted. For more information, see the End-of-Life Announcement for Laserfiche Digital Signatures.
To configure Filter Signatures
  1. Add the Get Document Signatures activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
  3. Under ClosedFilter Signatures in the Properties Pane, specify the types of signatures that will be retrieved.
    • Exclude countersignatures: Check this option to have this activity only retrieve signatures and ignore any countersignatures. Clear this option to retrieve all signatures and countersignatures.
    • Only include signatures on the latest version of the document: Check this option to have this activity only retrieve signatures on the latest version of the document. The activity will ignore the signatures on all previous versions of the document. Clear this option to retrieve signatures on all versions of the document.
