Error Codes
Many Workflow errors are accompanied by an error code. If you are running Workflow in another language, it is helpful to include the error code when working with Laserfiche support so that support can look up the error in English.
Below are lists of possible Workflow error messages:
Error Code Range 100-199
Error Code Range 200-299
Error Code Range 300-399
Error Code Range 400-499
Error Code Range 500-599
Error Code Range 600-699
Error Code Range 700-799
Some error messages come from the Laserfiche Server:
