Laserfiche Home Screen
The Laserfiche home screen is a dashboard-style home page that serves as a central access point for various Laserfiche products. From the home screen, you can view important documents, high-priority tasks, key metrics, reports, and forms. The home screen is the default landing page for Laserfiche Cloud.
If you are on another page in Laserfiche Cloud, you can access the home screen by clicking on the app picker app picker icon in the top right corner and selecting Home.
The home screen consists of the following sections:
  • Home: This is the landing page, containing widgets displaying key statistics, important documents, and tasks.
  • Documents: View summaries of favorite folder locations, starred documents, and perform searches within the repository.
  • Tasks: The page for managing tasks in your business processes.
  • Analytics: View statistics about your processes and repository.
  • Submit Forms: Quickly access forms that you can submit to start a business process.
Note: Some sections of the home screen described below may be unavailable because of security settings on your account, or because your organization did not purchase certain Laserfiche features.
Home Tab
The Home tab contains repository information, task information and help links.
Tip: Select a team from the drop-down menu to see the tasks and forms associated with that team.
Top Dashboard
Use the dashboard along the top of the Home tab to quickly see new and completed tasks, active tasks, open team tasks, and starred documents. Select any of these items to view your tasks or documents directly.
Task Information
If your organization uses Laserfiche business processes, you may have tasks assigned to you or your teams. The Home tab displays the numbers of these tasks and also provides lists of:
  • Tasks assigned to you, in My Active Tasks. These tasks are sorted with the most recently assigned tasks at the top.
  • Tasks assigned to you that have urgent, high, or medium priority levels, in My High-Priority Tasks. These are ordered from the highest priority to the lowest.
If there are too many tasks in these categories to display in the limited display area, you can click on More details to see the tasks that cannot be displayed.
To manage your tasks, click on the Tasks tab.
Repository Information
  • View a list of Starred Documents. This list is sorted with the most recently starred documents on top.
  • View a list of Recently Opened Documents. This list is sorted according to how recently the documents were opened, with the most recently opened ones on top.
  • Search the repository under Document Searches.
    • The Saved Searches subsection displays the 6 most recently saved searches.
If there are too many recently opened documents or starred documents to display in the limited display area, you can click on More details to see the complete lists of documents in those categories.
Forms
If there are forms available for you to fill out and submit, they will be listed in the Forms section. Submitting a form initiates the corresponding business process. For a process that does not start with a form submission, you can start the process from the Manage page under Business Processes or by using the starting link in the process's Process Details dialog.
Getting Help
The Help Center section in the Home tab helps you find tutorials, forum posts, and documentation on Laserfiche Cloud.
  • For video tutorials, click on Videos.
  • Click Answers if you have a question that you'd like to discuss with other Laserfiche users, or to search for solutions that other users have come up with.
  • Click Help to view the Laserfiche Cloud documentation.
Documents Tab
The Documents tab on the home screen provides you with a quick view of your starred documents, contents within your favorite folder locations, and provides quick searches of the repository.
You can configure the five widgets to display frequently used folders, or a list of starred documents from the repository. To configure one of the widgets:
  1. Click the Add button
  2. Select the folder to be displayed in the widget or select Starred in the left pane to display a list of starred documents
  3. Click Apply to activate the widget with the selected options.
To change the widget options, click the context menu button( Context Menu Image ) at the top right corner of the widget pane.
Saved document searches provide quick access to frequently accessed information through the Search widget.
Tasks Tab
The Tasks tab on the home screen lets you manage tasks for yourself and your teams. Learn more about how to complete tasks, view their details, reassign them, or change their due dates.
Analytics Tab
The Analytics tab on the home screen lets you view statistics and reports about business processes, forms, documents, and authentication attempts.
Operational Dashboard
ClosedSee a video on the Operational Dashboard
In this video, learn how to use the Operational Dashboard to monitor business processes, track task activity, and identify issues in real time. Quickly spot bottlenecks, take action, and keep your business processes running smoothly.
The Operational Dashboard provides at-a-glance visibility into Laserfiche Business Processes across tasks and process instances. Team managers and process participants can view what is currently running, where work is accumulating, and which items need attention. It also allows users to interact or intervene on tasks or instances if necessary.
Note: Reassigning or releasing tasks from the Operational Dashboard requires rights to manage or administer the underlying process, similar to Monitor. These rights exceed the Team Manager access right, which covers reassignment within a team from the Tasks tab. Reassign and release behave the same wherever you perform them.
Select the desired project and process in the dropdown lists.
The Tasks panel provides an overview of all task status types with breakdowns by assigned user, due state, assigned team, and longest duration. The Instances panel provides an overview of instance statuses, average duration, and occurrences by stage.
The Filters button allows you to select filters related to the elements in the panel. As each filter is selected, additional options for the filter are presented. The filter list is displayed across the top of the panel, allowing quick edits to or removal of either a single or all filters.
As you mouse-over elements, clickable items allow you to drill down into detailed tables about the elements. These tables provide users who have appropriate rights to perform tasks on multiple elements at once - similar to the listings in the Monitor pages. You can select up to 25 lines for action at a time, and the checkbox at the top left corner of the table will auto-select the first 25 rows.
View the Process reports tab for more out-of-box reports or Custom Reports to create custom data visualizations.
Sample operational dashboard
Process Reports
Select a process or form in the Process menu in the top right corner and choose one of the following types of reports to view. Use the Project and Process drop-down menus to select the specific process or survey you want to see data for.
  • Performance: View data about how quickly your process instances are being completed.
  • Work in Progress: View statistics about in-progress instances of business processes.
  • Task Loads: View a color-coded heat map that depicts which user tasks in a process are accumulating too many tasks and potentially creating bottlenecks.
  • Form Reports: View the field values of individual submitted forms and aggregated data from all submissions of a particular form.
  • Workload: View which users or teams have the most in-progress or complete tasks.
  • Irregularity: View suspended and terminated tasks to troubleshoot process issues.
Surveys
To see survey data, select the Surveys tab. Then select the team the survey is associated with and the survey you want to see data for.
Repository Reports
In the Repository section, you can quickly access the following reports on repository activity. Use the repository drop-down menu in the top left to select a repository.
  • Page Creations: View data on newly created pages.
  • Entry Deletions: View data on successful entry deletions.
  • Audit Reports: View a list of all reports you've made in Audit Trail Reporting. This list includes the above three reports by default.
Submit Forms Tab
The Submit Forms tab on the home screen and the Forms section on the Home tab display all forms available for submission. To start a business process that begins with a form, select the relevant form and submit it.
To submit a survey, navigate to the Manage section of the Surveys page or use the starting link in the Survey Details pane.
