For Each Entry
This activity runs the contained activities on each entry in a collection of entries. Learn about tokens this activity produces.
To set up this activity:
- In the Entries property box, select the collection of entries you want this activity to operate on by selecting the Edit button
, hovering over the activity you want to select the entry from, and selecting Output Entries. - In the Record Entries property box, select List the entries in the workflow's instance details if you want to list the entries in the instance report.
- Drag activities from the toolbox pane and drop them into this activity. These are the activities this activity will run.
Tokens for For Each Entry Activity
| Name | Description | Sample Syntax |
| CurrentEntry_Name | The name of the current entry. | %(ForEachEntry_CurrentEntry_Name) |
| CurrentEntry_Id | The Laserfiche ID number of the current entry. | %(ForEachEntry_CurrentEntry_Id) |
| CurrentEntry_Path | The folder path of the current entry. | %(ForEachEntry_CurrentEntry_Path) |
| CurrentEntry_FullPath | The folder path of the current entry, including the entry's name. | %(ForEachEntry_CurrentEntry_FullPath) |
| CurrentEntry_Repository | The repository the current entry is in. | %(ForEachEntry_CurrentEntry_Repository) |
| Iteration | The number of times the For Each Entry activity has run. | %(ForEachEntry_Iteration) |
The "ForEachEntry" portion of the syntax changes to match the activity's name.
Note: All non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity "Apply [Settings] to Each", the syntax for the CurrentEntry_Id token is "%(ApplySettingstoEach_CurrentEntry_Id)".
