Insert Pages
Use this property box to specify where pages copied or moved with the Move Pages activity will be inserted.
Note: The pages will be inserted into the document selected in the Move Pages To property box.
To configure Insert Pages
- Add the Move Pages activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- Under  Insert Pages in the Properties Pane, specify where the copied or moved pages will be inserted. Insert Pages in the Properties Pane, specify where the copied or moved pages will be inserted.
- Before first page: Inserts the pages before the first page of the document selected in the Move Pages To property box.
- After last page: Inserts the pages after the last page of the document selected in the Move Pages To property box.
- After Page: Inserts the pages after the specified page of the document selected in the Move Pages To property box.
-8.2.png)
