Move Pages
This activity moves or copies imaged pages between two Laserfiche documents or within the same Laserfiche document. See the token this activity produces.
- Activity Name
- Activity Description
- Action
- Move Pages From
- Move Pages To
- Page Range
- Insert Pages
Token for Move Pages
The Move Pages activity produces the following token.
| Move Pages Count | The number of pages the Move Pages activity moved or copied. | %(MovePages_Moved Pages Count) |
*The "MovePages" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. All non-alphanumeric characters, except underscores, are removed from the name.
Example: If you rename the activity "Transfer~Pages!," the syntax for the Shortcut Count token will be %(TransferPages_Move Pages Count).
