Selecting Entries for Activities
Some activities interact with entries other than the starting entry. These include:
- Activities that return or create entries.
See a list of these activities. - Activities that interact with entries returned or created by another activity.
See a list of these activities. - The condition dialog box in the Conditional Parallel, Conditional Sequence, Repeat, and Routing Decision activities lets you choose entries to specify conditions for.
- The Wait Conditions tab of the Route to Folder, Route to Group, and Route to User activities lets you choose an entry to specify conditions for.
Note: Not all activities allow you to choose which entries they will act on. Some activities will only act on the starting entry.
appropriate property box, choose which entry the activity will act on. - Starting Entry: The entry the workflow began with.
