Create Entry
This activity creates a Laserfiche document or folder. See the tokens this activity produces.
Tip: This activity cannot be used to create a shortcut. Laserfiche Routing activities and the Move Entry activity can both create shortcuts.
See the following options:
  • Activity Name
  • Activity Description
  • Entry Name
    This property box determines the name of the document or folder created by the Create Entry activity.
    To configure Entry Name
    1. Add the Create Entry activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
    3. Under ClosedEntry Name in the Properties Pane, enter a name for the new document or folder. Click the Token button (right arrow) Token button to use tokens.
  • Entry Type
    This property box determines the type of entry to be created by the Create Entry activity.
    To configure the Entry Type property box
    3. Under Entry Type in the Properties Pane, select either Folder or Document.
  • Destination
    This property box determines where the entry created by the Create Entry activity is saved.
    To configure the Destination property box
    3. Manually enter a location path, or click the Browse button (ellipsis) to open the Browse to Folders dialog . Alternately, click the Token button (right arrow) Token button to use tokens. You can only enter a destination within the Laserfiche repository specified in the Connection Profile.
    4. Select what you want the workflow to do if the destination you specify does not exist.
      • Create it: Creates a new folder path.
      • Create it and report a warning: Creates a new folder path, and displays a warning in the workflow instance details.
      • Terminate the workflow: Ends the workflow when it cannot find the folder path, and displays an error in the workflow instance details.
  • Default Volume
    This property box determines the Laserfiche volume that will contain the entry created by the Create Entry activity.
    To configure Volume
    3. Under Volume in the Properties Pane, select which volume the entry will be created in.
      • Select Use parent folder's volume, to create the new entry in the volume of the folder specified under Destination in the Properties Pane.
      • Select Look up volume by name, to create the new entry in a specified Laserfiche volume. Manually enter a volume, or click the Browse button (ellipsis) to open the Choose a volume dialog box. Alternatively, click the Token button (right arrow) Token button to use tokens.
  • Creation Options
    3. Under Creation Options in the Properties Pane, select additional options:
      • Return existing entry if found: If a document or folder with the same name already exists in the destination, the activity's output entry is set to the existing entry.
      • Place new entry under version control: Enable version tracking on the new document.
      • Change starting entry to be the output entry: Set the workflow's starting entry to the new entry.
Tokens for Create Entry
The Create Entry activity produces the following tokens.
OutputEntry_Name The name of the new entry. %(CreateEntry_OutputEntry_Name)
OutputEntry_Id The Laserfiche ID number of the new entry. %(CreateEntry_OutputEntry_Id)
OutputEntry_Path The folder path of the new entry. %(CreateEntry_OutputEntry_Path)
OutputEntry_FullPath The folder path of the new entry, including the entry's name. %(CreateEntry_OutputEntry_FullPath)
OutputEntry_Repository The repository the new entry is in. %(CreateEntry_OutputEntry_Repository)
OutputEntry_Server The Laserfiche Server that contains the new entry. %(CreateEntry_OutputEntry_Server)
OutputEntry_Guid The GUID (Globally Unique Identifier) of the new entry. %(CreateEntry_OutputEntry_Guid)
ParentEntry_Name The name of the folder in which the new entry was created. %(CreateEntry_ParentEntry_Name)
ParentEntry_Id The Laserfiche ID of the folder in which the new entry was created. %(CreateEntry_ParentEntry_Id)
ParentEntry_Path The folder path of the folder in which the new entry was created. %(CreateEntry_ParentEntry_Path)
ParentEntry_FullPath The folder path of the folder in which the new entry was created, including the folder's name. %(CreateEntry_ParentEntry_FullPath)
ParentEntry_Repository The repository that contains the folder in which the new entry was created. %(CreateEntry_ParentEntry_Repository)
ParentEntry_Server The Laserfiche Server that contains the folder in which the new entry was created. %(CreateEntry_ParentEntry_Server)
ParentEntry_Guid The GUID (Globally Unique Identifier) of the folder in which the new entry was created. %(CreateEntry_ParentEntry_Guid)
Created Parent Folder Whether the Create Entry activity created the folder in which the new entry was placed. This token can have one of two possible values: True or False. %(CreateEntry_Created Parent Folder)
*The "CreateEntry" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity New *Sales* Document, the syntax for the OutputEntry_Id token will be %(NewSalesDocument_OutputEntry_Id).
