Move Entry
This activity moves or copies a Laserfiche entry to a specified folder. It can also create a shortcut. See the tokens this activity produces.
See a video of a workflow that uses this activity
- Activity Name
- Activity Description
- Action
- Destination
- Entry to Move
Tokens for Move Entry
The Move Entry activity produces the following tokens. The "moved entry" referred to in the description below is either the entry itself, a shortcut to the entry, or a copy of the entry, depending on what you specify in the Move Entry activity's Action property box.
| OutputEntry_Name | The name of the moved entry. | %(MoveEntry_OutputEntry_Name) |
| OutputEntry_Id | The Laserfiche ID number of the moved entry. | %(MoveEntry_OutputEntry_Id) |
| OutputEntry_Path | The folder path of the moved entry. | %(MoveEntry_OutputEntry_Path) |
| OutputEntry_FullPath | The folder path of the moved entry, including the entry's name. | %(MoveEntry_OutputEntry_FullPath) |
| OutputEntry_Repository | The repository the moved entry is in. | %(MoveEntry_OutputEntry_Repository) |
| OutputEntry_Server | The Laserfiche Server that contains the moved entry. | %(MoveEntry_OutputEntry_Server) |
| OutputEntry_Guid | The GUID (Globally Unique Identifier) of the moved entry. | %(MoveEntry_OutputEntry_Guid) |
| ParentEntry_Name | The name of the folder the entry was moved into. | %(MoveEntry_ParentEntry_Name) |
| ParentEntry_Id | The Laserfiche ID of the folder the entry was moved into. | %(MoveEntry_ParentEntry_Id) |
| ParentEntry_Path | The folder path of the folder the entry was moved into. | %(MoveEntry_ParentEntry_Path) |
| ParentEntry_FullPath | The folder path of the folder the entry was moved into, including the folder's name. | %(MoveEntry_ParentEntry_FullPath) |
| ParentEntry_Repository | The repository that contains the folder the entry was moved into. | %(MoveEntry_ParentEntry_Repository) |
| ParentEntry_Server | The Laserfiche Server that contains the folder the entry was moved into. | %(MoveEntry_ParentEntry_Server) |
| ParentEntry_Guid | The GUID (Globally Unique Identifier) of the folder the entry was moved into. | %(MoveEntry_ParentEntry_Guid) |
| Created Parent Folder | Whether the Move Entry activity created the folder the entry was moved into. This token can have one of two possible values: True or False. | %(MoveEntry_Created Parent Folder) |
*The "MoveEntry" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity Transfer to ~Sales_Top~, the syntax for the OutputEntry_Id token will be %(TransfertoSales_Top_OutputEntry_Id).
