Destination
This property box determines the destination for the Move Entry activity. If you do not specify a location, the entry is not moved.
To configure the Destination property box
  1. Add the Move Entry activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
  3. Under ClosedDestination in the Properties Pane, type a location path, or click the Browse button (ellipsis) to browse to a folder. Alternatively, click the Token button (right arrow) Token button to use tokens.
  4. Note: You can only enter a destination within the Laserfiche repository defined.
  5. Select what should occur if the destination you select does not exist.
