Retrieve Document Text
This activity retrieves existing text from a Laserfiche or electronic document and stores it in a token. See the token this activity produces.
Tip: Using this activity in conjunction with the Pattern Matching activity can help you quickly extract useful information from pages of text.
Note: If the entry is an imaged document, the pages must be already OCRed to retrieve text. If the entry is an electronic document, the text must be already extracted to retrieve text. Learn more about generating text.
ClosedHow does this activity look in the Designer Pane?
Token for Retrieve Document Text
The Retrieve Document Text activity produces the following token.
Text The text of the specified document. %(RetrieveDocumentText_Text)
*The "RetrieveDocumentText" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity Proposal Contents..., the syntax for the Text token will be %(ProposalContents_Text).
