Retrieve Shortcuts
This activity collects all the shortcuts linking to a specified entry. After retrieving a set of shortcuts with this activity, you can perform a set of actions on each shortcut with the For Each Entry activity. See the token this activity produces.
- Activity Name
- Activity Description
- Retrieve Shortcuts From
Tokens for Retrieve Shortcuts
The Retrieve Shortcuts activity produces the following token.
| Result Count | The number of shortcuts the Retrieve Shortcut activity returned. | %(RetrieveShortcuts_Result Count) |
*The "RetrieveShortcuts" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. All non-alphanumeric characters, except underscores, are removed from the name.
Example: If you rename the activity "Find#Shortcuts#," the syntax for the Result Count token will be %(FindShortcuts_Result Count).
