For Each Entry
This activity runs the activities inside for each Laserfiche entry in a collection of entries that was returned or generated by a previous activity in your workflow definition. You must define which entries this activity will be performed on. See the tokens this activity produces.
For tips on how to use this activity, see Best Practices for Iterating Through Items in Workflow.
See an animation of this activity
Drag and drop activities into this activity.
Activity Name
Activity Description
Entries
Record Entries
The
Record Entries property box determines whether the entries used in the For Each Entry activity will be listed in the Entries tab of a workflow instance.Note: Using the Record Entries feature in the For Each Entry activity is recommended for troubleshooting purposes only. Reporting all entries, all the time, may increase the size of your SQL database.
To configure the Record Entries property box
- Add the For Each Entry activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- In the Properties Pane, select if you want to List the entries in the workflow's instance details.
Tokens for For Each Entry
The For Each Entry activity makes the following token, which are available to activities placed inside it. The For Each Entry activity runs one time per entry. Each time it runs, the token values reflect the information relevant to the entry it is currently processing.
| CurrentEntry_Name | The name of the current entry. | %(ForEachEntry_CurrentEntry_Name) |
| CurrentEntry_Id | The Laserfiche ID number of the current entry. | %(ForEachEntry_CurrentEntry_Id) |
| CurrentEntry_Path | The folder path of the current entry. | %(ForEachEntry_CurrentEntry_Path) |
| CurrentEntry_FullPath | The folder path of the current entry, including the entry's name. | %(ForEachEntry_CurrentEntry_FullPath) |
| CurrentEntry_Repository | The repository the current entry is in. | %(ForEachEntry_CurrentEntry_Repository) |
| CurrentEntry_Server | The Laserfiche Server that contains the current entry. | %(ForEachEntry_CurrentEntry_Server) |
| CurrentEntry_Guid | The GUID (Globally Unique Identifier) of the current entry. | %(ForEachEntry_CurrentEntry_Guid) |
| Iteration | The number of times the For Each Entry activity has run. | %(ForEachEntry_Iteration) |
*The "ForEachEntry" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity Apply [Settings] to Each, the syntax for the CurrentEntry_Id token will be %(ApplySettingstoEach_CurrentEntry_Id).
