Delete Annotation
This activity deletes an annotation added by an Add Sticky Note, Add Text Box, or Apply Stamp activity.
Activity Name
Activity Description
Annotation to Remove
The Delete Annotation activity's Annotation to Remove property box lets you delete an annotation that the Add Sticky Note, Add Text Box, or Apply Stamp activity added to a document earlier in the workflow.
To select an annotation to remove
- Add the Delete Annotation activity to your workflow by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
Annotation to Remove property box, click Select. - In the
Select Annotation dialog box, expand the activity that added the annotation you want to delete. - Click the green arrow
next to the annotation. - Click OK.
Note: You can only delete annotations added by activities that appear above the activity you are currently configuring in the Designer Pane.
