Assign Tags
This activity adds or removes tags to or from a Laserfiche entry.
See the following options:
Activity Name
Activity Description
Assign/Remove Tags
The
Assign/Remove Tags property box determines how the activity assigns or removes tags to or from a Laserfiche entry.To configure Assign/Remove Tags
- Add the Assign Tags activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- In the Properties Pane, click anywhere in the Assign/Remove Tags property box to open the
Tag Configuration dialog box. - Select tags to assign and/or remove.
- Optional: Add comments to tags that are being assigned.
Assign Tags To
