Generate Web Client URLs
This activity creates Web (http://) URLs and Laserfiche Mobile (LFMobile://) URLs for opening documents, folders, and search results in the Repository Web Client. The URLs are made available as tokens that you can use in other activities in your workflow definition.
Example: Use this activity to create a token for a Laserfiche entry and put this token in an email. The recipient of the email can use the generated URL to connect to the Web Client off-site and access the entry in the repository without having the Laserfiche Client installed.
ClosedHow does this activity look in the Designer Pane?
