Assign Rights
This activity assigns Laserfiche entry access rights to, or removes them from, a Laserfiche entry.
See the following options:
Activity Name
Activity Description
Rights Options
The
Rights Options property box determines how the activity will interact with Laserfiche entry access rights on a Laserfiche entry.To configure Rights Options
- Add the Assign Rights activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- Click any of the icons under Rights Options in the Properties Pane to open the
Rights Options dialog box. - Under Trustee, enter the user or group the activity will be applied to. Click the
Token button (right arrow) to use tokens. To choose from a list of trustees, click the
ellipsis button to open the Select Trustee dialog box. - In the Access Rights section, choose whether to Remove all rights or to Assign the following rights.
Note: If you select Remove all rights, rights will be removed from folders with a scope of This folder, subfolders, and documents, and rights will be removed from documents with a scope of This entry only.
- If you choose to Assign the following rights, select rights to be assigned or denied. Click Allow to enable a right and Deny to disable a right.
- To allow the selected entry to inherit rights from its parent, select the Inherit rights from parent when not specified above checkbox. Generally, you will want to enable inheritance.
Show me an example.
Note: Leave both the Allow and Deny columns blank to use inheritance.
Note: This option affects the entry access rights of all trustees, not just the selected one.
- To determine the scope of the rights, click If the entry is a folder, apply the rights to and select the most appropriate option. The drop-down choice "Immediate children only" refers to entries that are directly within the parent.
Show me an example.
Note: Access rights set by this activity will overwrite any previously existing rights if applied to the same scope and user.
Example: Bob is given the Browse and Read access rights to the Sales Department folder. Later, a workflow assigns him the Browse and Rename access rights with the same scope. After that workflow runs, Bob's access rights to the Sales Department folder will be Browse and Rename, and he will no longer have the Read access right.
Assign Rights To
to open the
