Trustees
Interacting with trustees
There are several ways that a workflow can interact with Laserfiche, LDAP, and Laserfiche Directory Server trustees. A workflow can
- Assign Laserfiche repository rights to a user or group.
- Send an email to a user or group..
- Notify business process participants of pending work. Learn about sending email notifications or providing instructions in the Laserfiche client applications.
- Route a Laserfiche entry to a user or group's folder.
- Assign Workflow-specific permissions and access rights to a user or group.
- Find a user or group and retrieve information associated with that user or group.
- Set a user as an entry's owner.
- Create a Laserfiche Directory user.*
- Assign a User License in a Laserfiche Directory.*
- Create a Laserfiche Directory group.* .
- Assign a trustee to groups in a Laserfiche Directory Server.*
- Delete a Laserfiche Directory trustee.*
*Note:These Workflow interactions are only available with Laserfiche Directory Server trustee directories.
Using trustee properties
You can assign each trustee specific properties so that when a workflow looks for a trustee based on one property, it can retrieve additional information about the trustee. By default, these are the trustee properties that you can assign values to:
- User Name*
- Department*
- Organization*
- Display Name
- Email address
- Default Folder
- First Name
- Last Name
*Note: These trustee properties are only available with Laserfiche Directory Server trustee directories.
Tip:You can create additional, custom properties (advanced).
Example: A workflows routes a document to Jill. If you have specified Jill's properties, then, using tokens, you can easily configure the workflow to send the document directly to Jill's default folder and use Jill's display name in an email notification.
Adding trustee directories
Workflow will only interact with a Laserfiche, LDAP, or Laserfiche Directory Server trustee directory if it appears in the Workflow Administration Console's Trustee Directories node.
- You can add a Laserfiche trustee directory by configuring a monitored repository in the Workflow Configuration Manager or the Repositories node of the Workflow Administration Console.
- You can add an LDAP trustee directory with the Trustee Directory Manager.
- You can add a Laserfiche Directory Server directory with the Trustee Directory Manager.
See also:
