Assign User License in Laserfiche Directory
This activity assigns a license to a Laserfiche Directory Server user.
See the following options:
Activity Name
Activity Description
Server
Select the name of your Laserfiche Directory Server.
License
Select the type of license to assign the user.
Assign License To
Click the Select link and choose the User you wish to add to group(s) from the dialog window.
