Assign Trustee To Groups in Laserfiche Directory Server
This activity adds or removes a trustee to or from groups in Laserfiche Directory Server.
See the following options:
Activity Name
Activity Description
Server
Select the name of your Laserfiche Directory Server.
Action
Add trustee to groups: Select to add the chosen trustee to the specified groups.
Remove trustee from groups: Select to remove the chosen trustee from the specified groups.
Trustee
Click the Select link and choose the Trustee you wish to add to group(s) from the dialog window.
Groups
Enter the name of the Group(s) you wish to assign the Trustee.
Note: Use the browse button
to choose existing Groups.
