Create Laserfiche Directory User
This activity adds a new user to the Laserfiche Directory Server.
See the following options:
Activity Name
Activity Description
Server
Select the name of your Laserfiche Directory Server.
User Information
- Click the following area to configure the user.
- In the Create Directory User window, input the parameters for the user you wish to create.
- User Type
- Laserfiche User
- SAML User
- Organization: Choose your organization using the browse button.
- For SAML User Type: Choose an Identity Provider using the browse button.
- User Information: Click on each User Information field and use the Value field to input the desired value.
- User Type
- Click OK.
Tokens for Create Laserfiche Directory User
The Create Laserfiche Directory User activity produces the following tokens.
| ID | The ID of the user created by the Create Laserfiche Directory User activity. | %(CreateLaserficheDirectoryUser_ID) |
| Display Name | The display name of the user created by the Create Laserfiche Directory User activity. | %(CreateLaserficheDirectoryUser_Display Name) |
| Account Name | The account name of the user created by the Create Laserfiche Directory User activity. | %(CreateLaserficheDirectoryUser_Account Name) |
| The e-mail address of the user created by the Create Laserfiche Directory User activity. | %(CreateLaserficheDirectoryUser_E-mail) | |
| Working Folder | The working folder for the user created by the Create Laserfiche Directory User activity. | %(CreateLaserficheDirectoryUser_Working Folder) |
| Default Folder | The default folder for the user created by the Create Laserfiche Directory User activity. | %(CreateLaserficheDirectoryUser_Default Folder) |
| Managers E-mail | The e-mail address(es) of the manager(s) of the user created by the Create Laserfiche Directory User activity. | %(CreateLaserficheDirectoryUser_Managers E-mail) |
*The "CreateLaserficheDirectoryUser" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name.
