Find User
This activity searches for a user and provides information about the user as tokens. See the tokens this activity produces.
Activity Name
Activity Description
Lookup Options
This property box determines which user(s) the activity will look for and retrieve information (properties) about.
To configure Lookup Options
- Add the Find User, Find Group, or Find Manager activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
Lookup Options in the Properties Pane, use the drop-down menu next to Search in to choose which trustee directory the activity will look in for users. - Optional: If the desired directory is not listed, select Manage Directories in the drop-down menu to add a trustee directory from the Trustee Directory Manager dialog box.
- Select to search for A specific user or A user from a token.
- Select A specific user or A specific group.
- Click the Browse button (ellipsis)
to search for a user group in the
Trustee Search dialog box. - In the Trustee Search dialog box, enter a user or group's name in the Search Value text box.
- Click Search.
- If a user or group is found, the user or group's properties will appear in the Properties section of the dialog box.
- Optional: You can update a user or group's properties in this dialog box.
- Click OK.
- Select A user from a token or A group from a token.
- Manually enter a token, or click the Token button (right arrow)
to select a token. - In the drop-down menu under Find user by or Find group by, select which user/group property the token refers to.
Note: If you are configuring this property box for the Find Manager activity, specify the user whose manager(s) you want to find information about. If you are configuring this property box for the Find User or Find Group activity, specify the user or group you want to find information about.
To search for a specific user or group
To search for a user or group from a token
Example: The token %(Initiator) represents the initiator's account name. If you select the token %(Initiator), choose Account Name from the drop-down menu under Find user by. If you select the token %(RouteEntrytoUser_User_E-mail), choose E-mail from the Find user by drop-down menu.
Note: If you choose the wrong property in the Find user by menu, the activity will try to retrieve the user/group by looking through each property in turn, and it may take longer for the activity to complete.
Advanced Properties
Click the Advanced button
at the top of the Properties Pane to view and configure Folder Token Settings.This optional property box determines the Working Folder for the user, group, or manager(s) found with the Find User, Find Group, and Find Manager activities. The Working Folder's path will be stored in the Working Folder token which can be used in other activities in the Workflow.
Note: This property box is optional and rarely used. If you would like to see this property box, click the Advanced button
at the top of the Properties Pane. To configure Folder Token Settings
- Add the activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- Click the Advanced button
at the top of the Properties Pane. - In the
Folder Token Settings property box, specify the Working Folder's token value for this activity.
Example: If you configure this property box for the Find User or Find Group activity, the folder you specify will be the Working Folder for the user or group found. If you configure this property box for the Find Manager activity, the folder you specify will be the Working Folder for each manager found. In this situation, the Working Folder token will only contain the path of the first manager's Working Folder. To access the tokens for the other managers' working folders, you must use a For Each User or For Each Row activity.
- Select Use this folder collection to use a folder pair specified in a folder collection. Folder collections are lists of folder and user/group pairings that can be used with different activities within a workflow..
- Select a folder collection from the drop-down menu.
- Optional: If you want to add, modify, or delete a folder collection, click Manage folder collections.
- Select Use this folder for all other users to specify a folder to be used as the Working Folder for this activity.
- Type a folder path in the text box, or click the Browse button (ellipsis)
to browse for a folder. Alternatively, click the Token button (right arrow)
to use tokens. - Select both options to use the specified folder only if a user is not listed in the selected folder collection.
- Clear both options to use the user or group's default folder.
Example: You create a folder collection of folders for team leaders from several departments. By choosing the Team Leader folder collection, you can retrieve a person's team leader folder instead of his or her default folder.
Note: If a user or group is not part of the folder collection selected, the user or group's default folder will be retrieved instead. Learn more about using trustees in Workflow.
Note: If you clear both options and no default folder is specified for the user or group, the default folder or Working Folder tokens from this activity will be blank. In many cases, using a blank token will cause an error that terminates the workflow.
Tokens for Find User
The Find User activity produces the following tokens.
Note: If a user's Display Name is not set, the value for the user's Account Name is used for the Display Name token instead.
| Results Found | Whether a user was found by the Find User activity. This token can have one of two possible values: True or False. | %(FindUser_Results Found) |
| ID |
The ID of the user found by the Find User activity. Note: For LDAP and Windows users, the ID token is replaced by the user's SID. For Laserfiche users, the ID token is replaced by the user's ID, not their SID. |
%(FindUser_ID) |
| Display Name | The display name of the user found by the Find User activity. | %(FindUser_Display Name) |
| Account Name | The account name of the user found by the Find User activity. | %(FindUser_Account Name) |
| The e-mail address of the user found by the Find User activity. | %(FindUser_E-mail) | |
| Is Group | Whether the user found by the Find User activity is a group. The value of this token is always False. | %(FindUser_Is Group) |
| Qualified Name | The unique identifying name of the user found by the Find User activity. | %(FindUser_Qualified Name) |
| Working Folder | The working folder for the user found by the Find User activity. The working folder is the folder specified in the Find User Folder Token Settings property box. If no folder is specified in this property box than the working folder is the default folder. | %(FindUser_Working Folder) |
| Default Folder | The default folder for the user found by the Find User activity. | %(FindUser_Default Folder) |
| Managers E-mail | The e-mail address(es) of the manager(s) of the user found by the Find User activity. If the user has more than one manager, their e-mail addresses will be listed as a multi-value token. | %(FindUser_Managers E-mail) |
*The "FindUser" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity Accountant <A>, the syntax for the ID token will be %(AccountantA_ID).
