For Each User
This activity runs the activities inside it for each user in the specified group. You can return groups for this activity to use with a Find Group or Find Manager activity. See the tokens this activity produces.
For tips on how to use this activity, see Best Practices for Iterating Through Items in Workflow.
- Drag and drop activities into this activity.
Activity Name
Activity Description
Get Users From
The For Each User activity can dynamically interact with groups found with the Route Entry to Group, Find Group, or Find Manager activities.
To select which group the activity will run on
- Add the For Each User activity to your workflow by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- Under Get Users From in the Properties Pane, click Select.
- In the Select User dialog box, expand the activity that finds the group or users you want to use with the For Each User activity.
- Click the green arrow
next to the group or users you want to use. - Click OK.
Note: You can only select groups from activities that appear above the activity you are currently configuring in the Designer Pane.
Folder Validation
This property box determines if users without a default folder or Working Folder will be skipped in the For Each User activity. Learn more about Working Folders.
To configure Folder Validation
- Add the For Each User activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- Under Folder Validation in the Properties Pane, select the check box to skip users who do not have a default folder or Working Folder specified.
Tokens for For Each User
The For Each User activity produces the following tokens, which are available to activities placed inside it. The For Each User activity runs one time per user, group, or manager. Each time it runs, the token values reflect the information relevant to the user it is currently processing.
Note: If a user's Display Name is not set, the value for the user's Account Name is used for the Current User_Display Name token instead.
| Current User_Id | The current user's ID. | %(ForEachUser_Current User_Id) |
| Current User_Display Name | The current user's Display Name. | %(ForEachUser_Current User_Display Name) |
| Current User_Account Name | The current user's Account Name. | %(ForEachUser_Current User_Account Name) |
| Current User_E-mail | The current user's e-mail address. | %(ForEachUser_Current User_E-mail) |
| Current User_Is Group | Whether the current user is a group. This token can have one of two values: True or False. | %(ForEachUser_Current User_Is Group) |
| Current User_Qualified Name | The current user's unique identifying name. | %(ForEachUser_Current User_Qualified Name) |
| Current User_Working Folder | The current user's working folder. The working folder is the user's folder specified in the Find User, Find Group or Find Manager Folder Token Settings property box. If no folder is specified in this property box than the working folder is the default folder. | %(ForEachUser_Current User_Working Folder) |
| Current User_Default Folder | The current user's default folder. | %(ForEachUser_Current User_Default Folder) |
| Current User_Managers E-mail | The e-mail address(es) of the current user's manager(s). If the current user has more than one manager, their e-mails will be listed in a multi-value token. | %(ForEachUser_Current User_Managers E-mail) |
| Iteration | The number of times the For Each User activity has run. | %(ForEachUser_Iteration) |
*The "ForEachUser" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity Distribute-to-User, the syntax for the Current User_Id token will be %(DistributetoUser_Current User_Id).
