For Each Row
This activity runs the activities inside it on each row returned by the Custom Query and Query Data activities or on each result returned by activities that return collections of information, such as Search Repository, Find Entries, Find Manager, Find Group, Retrieve Laserfiche Forms Content, and Verify PDF Signatures.
For tips on how to use this activity, see Best Practices for Iterating Through Items in Workflow.
Note: When using SELECT queries in the Custom Query activity, you must test the query in order to make the columns accessible as tokens to this activity.
Drag and drop activities into this activity.
Activity Name
Activity Description
Get Rows From
The For Each Row activity can dynamically interact with rows found with activities that return collections of information such as the Custom Query, Query Data, Search Repository, Find Entries, Find Manager, Find Group, Retrieve Laserfiche Forms Content, and Verify PDF Signatures activities.
To select which collection of information the activity will be performed on
- Add the For Each Row activity to your workflow by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
Get Rows From in the Properties Pane, click Select. - In the
Select Collection dialog box, expand the activity that finds the collection of information you want to use with the For Each Row activity. - Click the green arrow
next to the collection of rows you want this activity to use. - Click OK.
Note: You can only select collections of information from activities that appear above the activity you are currently configuring in the Designer Pane.
Tokens for For Each Row
If you have a Custom Query activity that uses a SELECT query and you test the query first, the activity creates one token per column in the database table. These tokens are available to activities inside the For Each Row. The For Each Row activity runs one time per row in the column. Each time it runs, the token value reflects the information relevant to the row it is currently processing.
| Column Name | A token is created for each column in the database table. The token name is the same as the column name. The token's value is the value in the Column Name column of the current row. | %(ForEachRow_Column Name) |
| Iteration | The number of times the For Each Row activity has run. | %(ForEachRow_Iteration) |
*The "ForEachRow" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity Process [Rows], the syntax for the column named "Addresses" token will be %(ProcessRows_Adddresses).
