Custom Query
This activity performs a specified query in a database. See the tokens this activity produces.
See the following options:
Activity Name
Activity Description
Data Source
This property box determines which data source the activity will use.
To select a data source
- Add a Custom Query, Insert Data, Query Data, or Update Data activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
Data Source in the Properties Pane, select a data source from the drop-down menu. - Optional: To add, configure, remove, or test a connection to an external data source, select Manage Data Sources from the drop-down menu. Learn more about data source administration.
- Optional: Click the refresh icon
to update the list of data sources available in the drop-down menu.
Note: Because the Workflow Server performs the data-source queries, you must create all data sources on the Workflow Server. Services cannot access mapped drives when you are setting up the data source.
Custom Query
This property box allows you to insert a custom query to specify which table the Custom Query activity will search and which row's values it will return as tokens. This activity returns the values of the first row it finds as tokens. It also returns the collection of rows that have the specified column values.
Note: If this activity returns a collection of rows, you can access the tokens for each row with the For Each Row activity.
To configure Custom Query
- Add the Custom Query activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
Custom Query in the Properties Pane, click in the box below Query to create a custom query. - In the
Custom Query Editor, enter your custom query under Custom Query. - Optional: Type your Parameter Name under Parameter Names. How to specify the parameter names depends on how you are connecting to the data source:
- When using an ODBC connection, you cannot use named parameters. Use "?" for each parameter name. They are interpreted in the order in which they are listed.
Show me what this looks like. You must list a parameter each time you use one in the query, even if you use the same parameter twice in the same query. - To use named parameters, use an OLE DB connection. Named parameters can be used more than once in the query without being listed more than once in the parameter list.
Show me what this looks like. - Optional: Type your Parameter Value under Parameter Values, or click the Token button (right arrow)
to use tokens. - Optional: Choose a type for your parameter from the Type drop-down menu. You will want to set a parameter type if you are invoking a stored procedure that expects a specific type. Also, not all database drivers/servers automatically convert strings to the desired parameter type, so you might want to manually set the type in that situation. In most cases, you will want to leave the type as default. More info.
- When you enter a parameter name or value, an additional line appears for you type additional parameter names and values in. As you continue to type parameter names and values, additional lines appear.
- Optional: Remove a parameter name and value by clicking the red X
. - Click OK.
- Optional: To modify your query, click Edit in the Custom Query property box, or click anywhere in the Query or Parameters boxes. Repeat steps 4 through 9.
- Click the Test link to test your query.
- In the Define Query Parameters dialog box, insert the value you want to test.
- Click OK.
- The Test Query dialog box displays how many rows the query will return or any error (with accompanying error message) it encounters.
- Click OK.
Note: Different database sources have different syntaxes. The example below is written for the MSSQL ODBC. All queries are written in SQL. Use the correct syntax for your data source.
Tip: If you want a token to be replaced by the null value in the case that the token's value is blank (the empty string), apply the NULL token formatting expression. If you want to set a column's value to the null value regardless, insert the NULL token: %(DB.NULL).
Note: When using a SELECT query, you must test the query in order to make the columns accessible as tokens to the For Each Row activity.
Rows to Return
This property box determines how many rows the activity will return.
Note: If you chose to have these activities return more than one row, you can access the token values for the additional rows with the For Each Row activity.
To configure Rows to Return
- Add the Query Data or Custom Query activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
Rows to Return in the Properties Pane, specify how many rows you want returned. - First row only: Returns the first row in the database that contains the queried value. The database is searched from the top down.
- First ___ rows: Returns the first specified number of rows that contain the queried value. Type in the desired number of rows, or use the scroll box (up-and-down arrows)
to select a number of rows. Alternatively, click the Token button (right arrow)
to use tokens. The database is searched from the top down. - All Rows: Returns all rows that contain the queried value.
Query Options
This property box allows you to specify a custom timeout for data query activities.
To specify a custom timeout
Query Options in the Properties Pane, select the Specify a custom timeout check box and specify the desired timeout value in seconds.
Note: The default timeout value is 30 seconds.
Tokens for Custom Query and Query Data
The Custom Query and Query Data activities produce the following token.
| Results Found | Whether results were found by the query. This token can have one of two values: True or False. | %(CustomQuery_Results Found) |
| Result Count | The number of results found with the Custom Query or Query Data activity. | %(CustomQuery_Result Count) |
*The "CustomQuery" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity Query "Database A_1", the syntax for the Results Found token will be %(QueryDatabaseA_1_Results Found).
The first row of the queried table are available as tokens
When a query is run, a token is created for each column in the table returned. Each token contains its column's value in the first row returned by the query. If you want to access tokens for additional rows, use a For Each Row activity.
To use first row tokens in the Workflow Designer, you must first test this query. Learn more about testing queries.
| Column Name | A token is created for each column of the first row of the database table. The token name is the same as the column name. The token's value is the value in the Column Name column of the current row. | %(CustomQuery_Column Name) |
*The "Column Name" portion of the syntax changes to match the column name in the first row of the specified table. Note that all non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity Process [Rows], the syntax for the column named "Addresses" token will be %(ProcessRows_Addresses).
Column tokens available with the For Each Row activity
The Custom Query and Query Data activities also produce one token per column in the database table, which are available to activities inside the For Each Row activity. With the Custom Query activity you must use a SELECT query and test the query first to access these tokens. The For Each Row activity runs one time per row in the column. Each time it runs, the token value reflects the information relevant to the row it is currently processing.
| Column Name | A token is created for each column in the database table. The token name is the same as the column name. The token's value is the value in the Column Name column of the current row. | %(ForEachRow_Column Name) |
*The "ForEachRow" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity Process [Rows], the syntax for the column named "Addresses" token will be %(ProcessRows_Addresses).
