Verify PDF Signatures
This activity verifies whether the signatures on a PDF are trusted and produces tokens with information about the signatures. See the tokens this activity produces.
- Activity Name
- Activity Description
- Entry
Tokens for Verify PDF Signatures
The Verify PDF Signatures activity produces the following tokens.
| Sign Date | The date each user signed the PDF, listed in a multi-value token. | %(VerifyPDFSignatures_Sign Date) |
| Sign Reason | The reason each user gave for signing the PDF, listed in a multi-value token. | %(VerifyPDFSignatures_Sign Reason) |
| Signature Is Modified | Whether the PDF was modified after the user signed it. If more than one user signed the PDF, this token lists (as a multi-value token) whether the PDF was modified after each of the users signed it. | %(VerifyPDFSignatures_Signature Is Modified) |
| Signature Is Trusted | Whether the signature is trusted. If the PDF has more than one signature, this token lists (as a multi-value token) whether each of the signatures is trusted. | %(VerifyPDFSignatures_Signature Is Trusted) |
| Signature Count | The number of users who signed the PDF. | %(VerifyPDFSignatures_Signature Count) |
| Is Trusted | Whether all signatures on the PDF are trusted. | %(VerifyPDFSignatures_Is Trusted) |
| Is Modified | Whether the PDF was modified after any of the users signed the document. | %(VerifyPDFSignatures_Is Modified) |
| Signer | The name of each user who signed the PDF, listed in a multi-value token. | %(VerifyPDFSignatures_Signer) |
*The "VerifyPDFSignatures" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity Check_Signers/Reasons, the syntax for the Sign Date token will be %(Check_SignersReasons_Sign Date).
