Query Data
This activity retrieves rows of data from a database and makes the data available as tokens.
Activity Name
Activity Description
Data Source
This property box determines which data source the activity will use.
To select a data source
- Add a Custom Query, Insert Data, Query Data, or Update Data activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
Data Source in the Properties Pane, select a data source from the drop-down menu. - Optional: To add, configure, remove, or test a connection to an external data source, select Manage Data Sources from the drop-down menu. Learn more about data source administration.
- Optional: Click the refresh icon
to update the list of data sources available in the drop-down menu.
Note: Because the Workflow Server performs the data-source queries, you must create all data sources on the Workflow Server. Services cannot access mapped drives when you are setting up the data source.
Query Criteria
This property box determines which table the Query Data activity will search and which row's values the activity will return as tokens. This activity will return the values of the first row it finds as tokens. It also will return the collection of rows that have the specified column values.
Note: This activity produces a token for each column in the specified table. The tokens for the first row the query finds are available to other activities in the workflow. If you want to access tokens for additional rows, use a For Each Row activity.
Note: You must configure the Data Source property box before configuring this property box.
To configure Query Criteria
- Add the Query Data activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
Query Criteria in the Properties Pane, select the table you want to query from the drop-down menu. - Click Add in the Query Criteria property box.
- In the
Add Query Criteria dialog box, select the column you want to query from the Column drop-down menu. - Next to Value, type in a value to search for in that column, or click the Token button (right arrow)
to use tokens. - Click OK.
- Click an existing query in the Query Criteria property box.
- Click Edit.
- In the Edit Query Criteria dialog box, modify the search value. Click the Token button (right arrow)
- Click Remove.
- Click the Test Query link to test your query.
- If prompted, in the Define Query Parameters dialog box, insert the value you want to test.
- Click OK.
- The Test Query dialog box will display how many rows the query will return or if there are any errors.
- Click OK.
To Add a Query
Tip: If you want a token to be replaced by the null value in the case that the token's value is blank (the empty string), apply the NULL token formatting expression. If you want to query a column for the null value, insert the NULL token: %(DB.NULL).
To Edit a Query
To Remove a Query
Rows to Return
This property box determines how many rows the activity will return.
Note: If you chose to have these activities return more than one row, you can access the token values for the additional rows with the For Each Row activity.
To configure Rows to Return
- Add the Query Data or Custom Query activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
Rows to Return in the Properties Pane, specify how many rows you want returned. - First row only: Returns the first row in the database that contains the queried value. The database is searched from the top down.
- First ___ rows: Returns the first specified number of rows that contain the queried value. Type in the desired number of rows, or use the scroll box (up-and-down arrows)
to select a number of rows. Alternatively, click the Token button (right arrow)
to use tokens. The database is searched from the top down. - All Rows: Returns all rows that contain the queried value.
Query Options
This property box allows you to specify a custom timeout for data query activities.
To specify a custom timeout
Query Options in the Properties Pane, select the Specify a custom timeout check box and specify the desired timeout value in seconds.
Note: The default timeout value is 30 seconds.
