Routing Options User
This property box contains routing options for the Route Entry to User activity.
To configure Routing Options
  1. Add the Route Entry to User activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
  3. Under Routing Options in the Properties Pane, click any of the setting's icons to open the Routing Activity Options dialog box. This box consists of seven tabs:
